WELCOME TO GTIROZ!
The Nissan GTI-R Owners Club Australia
LOOKING TO BUY A GTI-R IN AUSTRALIA?
We maintain a list of every Nissan Pulsar GTI-R that we find publicly available for sale in Australia HERE.
ALREADY AN AUSTRALIAN GTI-R OWNER?
Founded in 2000, GTIROZ has been running this private forum since 2005. It is the core basis and historical database of the club. Since most people are on FB we also run a "group" THERE, but we highly encourage all Australian owners to make the effort to JOIN this proper, private forum, where we are in full control of our own data. You can benefit from many years of collective, organised, searchable ownership experience, and contribute your own to future GTI-R owner generations.
[QLD] ‘92 Black Built Project $20k
Ad taken off fb.
https://www.facebook.com/marketplace/profile/722351292/?ref=permalink&tab=listings
#4sale With a bit of a sad face, I’m having to part ways with the hillclimb project. RA in black and complete. Only missing the umbrella. Produced 350kw/650Nm @ wheels on e85. Currently in pieces including the block.
First, why it’s in pieces. The sleeve in cylinder 3 gave up on life. General consensus with 3 different professionals is that a manufacturing defect in the sleeve itself finally let go with coolant escaping in to the cylinder. Because the engine was shutdown straight away there was no damage beyond the sleeve. However, secured a new set of piston rings anyway. I would be replacing the sleeves but as some of you would know they are next to impossible to come by and life is taking me in another direction.
The car had only travelled 160 kays after the build. ☹️
Now for the good stuff! All these parts have only travelled 160 kays;
- Spool 2.2L Stroker Kit
    - Crank
    - Rods
    - 86.5mm Pistons
- Garrett GTX3884R
- Twin Turbosmart 38mm external wastegates
- Autronic SM-4 ECU
- Greddy Boost Controller
- Camtech 280 degree 12.5mm lift cams
- Brian Crower valves and twin spring set with titanium retainers
- LS coils/distributor delete
- $12,000 invested in gearbox, built by NEAT gearboxes in Adelaide;
- PPG Straight Cut 1-4
- PPG Final
- Stratcher Motorsport gearbox brace welded
- Stratcher Motorsport bell housing brace welded
- Competition Clutch twin plate race
- JGY Custom fuel rail
- Bosch motorsport 1600 injectors
- Turbosmart Fuel Pressure Regulator
- Aftermarket Industries SP800 surge tank with Twin Walbro 460 plus pumps
- In-tank Walbro 460plus pump
- Custom intake/intercooler piping
- Alloy radiator and fan
- Custom catch can
- Alloy coolant tank
- K&N air filter
- Custom exhaust manifold/dump ceramic coated and side exit exhaust
- Optima Dry cell battery
- Air con delete
- Carbon canister delete
Also included but not fitted/spares
- Full Tein coilover/white line handling kit
- Second gearbox and gearset, unknown condition
- Second transfer case, unknown condition
- All the original parts that made way for the current build including an older Garret GT3582R
The only other thing I would have done to this car is bigger front brakes. Other than that she is sweet. 👌
Of course, would like to sell the lot. Not considering parting out/splitting at this stage.
Have other photos and can take more at request. Can produce dyno sheet and a whole bunch of receipts at request.
Located Western Brisbane. Inspection encouraged.
$20,000
Mark - 0422493248
Rego:
VIN: RNN14-051737
KM: 165xxx
