WELCOME TO GTIROZ!
The Nissan GTI-R (RNN14) Owners Club Australia
LOOKING TO BUY A GTI-R?
We maintain a list of every Nissan Pulsar GTI-R for sale in Australia that we find publicly available HERE.
ALREADY AN OWNER?
Founded in 2000, we have been running this private forum since 2005. It is the core basis and historical database of the club. Since everyone is on FB we also run a "group" THERE, but we highly encourage all Australian owners to JOIN this real forum, where we are in full control of our own data, and benefit from many years of collective, organised, searchable ownership experience.
[NT] ‘90 White $19.9k
http://www.gumtree.com.au/s-ad/1260696617?
1990 Nissan Pulsar GTiR
Rebuilt Engine (standard internal specs)- not yet run in.
VIN; 6T91MPAAALYAAB007 (personal import)
Chassis; RNN14-002852
Many extras as below;
- high flowed turbo (standard turbo with larger impeller & machined housing to suit)
- Front mount intercooler
- Turbo smart bleed valve (set at low boost setting after rebuild)
- All hoses under intake manifold replaced with silicon type- new
- 3” exhaust
- Dump pipe
- Quick shift
- Upgraded suspension (non-height adjustable)
- 17” wheels
- Rings, big end bearings, timing chain & guides, front seal, gaskets & o-rings (as applicable) all new. No oil or water leaks.
- Head was replaced with an excellent used item. Nil camshaft lobe or lash pad wear. No excessive tapper noise.
- New front lower arms (RH & LH)
- K&N air cleaner pod
- Aftermarket recirculating BOV
- APEXi turbo timer
- APEXi rev/speed meter
- Updated clutch (unknown brand)
- Pioneer CD/ USB stereo
- Under dash colours LED lighting
- New battery, oil, filter, fuel filter, air cleaner washed out.
Serviced ready to go.
Car drives very well & presents very well but is not perfect. Interior is clean & tidy. There are some small spots of surface rust in a few places that have been touched up.
Car has had a open door respray a long time ago - changed from off-white to brilliant white. It was a reasonable job but has a few blemishes now.
Some small shopping type dents - mostly inconspicuous but RH guard needs some attention to make it more presentable.
Aircon doesn’t work (no gas) but is complete.
In summary, this is a good solid car that would make a good reliable daily driver. Give it some more TLC to the body over time to make it immaculate or just drive. As it is, it looks good, sounds good & turns heads. It’ll be an appreciating asset as the prices keep rising.
Car is at Uluru (yes, The Rock!) - come for a holiday & drive it home. Or can deliver to transport depot in Alice Springs if required.
$18,000 negotiable (within reason)
Darren 0412 422 272
Rego:
VIN: RNN14-002852
KM: 223xxx
Previous ad: https://www.gtiroz.net/topic/15733-sold-qld-‘90-ivory-5k/
5306E67F-BA07-413A-833E-65A08DE98510.jpeg.203ef201e66c1c8c0af0f42ab60658c8.jpegB99371BD-8EA5-4689-A58D-1611BFAA4344.jpeg.5eae698d7a66f81eb9719c9db806c4fd.jpeg
