[SOLD] [SA] ‘91 Red built motor $16.5k
http://www.gumtree.com.au/s-ad/1245476158?
Nissan PULSAR GTIR AWD TURBO
Mericulously maintained and with over $25,000 in reciepts
Engine has covered under 2500 since its build with proof.
*Engine*
Some of the Mods Include
• Garrett 3076 Turbo with over $1500 spent in on ou n top of the purchase price to suite the new Tomei Pon Cams
• Heads Sonic Blasted and CNC Ported to suit Cams
• Tomei Pon Cams With Solid Lifters
( An expensive modification to perform )
• Manley Forged Pistons
• Spool Rods
• Block Dipped, Line Bored , Decked and Chemically Treated
• New Race Bearings e.t.c
• All Assembled by Harmond Engine Developments and professionally installed.
Much more in reciepts but just have rlwritren some of the main parts.
• Maintanace
Run in oil changed as soon as needed and has had oil changed again at 1000kms then recently at 1500 kms with Penrite 10 Tenths with added moly . Recommended for cammed Engines
Transmission
•Transmission was imported then pulled apart and inspected with all necessary clearances checked and new syncro's were needed
• XTREME Heavy Duty Clutch and Flywheel
• New Slave Cylinder
Both Differentials and Transmission have recently had a fresh oil change with Top Quality oils.
• Exhaust
Custom Stainless system from Turbo Back
As new as the engine build Sounds and Performs Brilliantly
ECU
LATEST Nistune Version 3 with Harness included as well
Z32 Airflow Meter
Brand New Walbro 255 l/ ph Fuel pump
Injectors are standard as I didnt want to put strain on the new engine and clutch .
They have been flowed and cleaned.
Custom Dyno Tuned at only 10 psi and made 207 All Wheel Kilowatts at a conservative Tune.
This Turbo and cam set up has the potential for over 350 All wheel Killowatts ifnpushednto 27psi which thenginenandnturbo is capable off.
However for me 200 plus all wheel killowattsbis all I wanted reliably.
I dontnpush the car hard , I just wanted it built to last.
As you are Aware these Vehicles are Extremely rare and sought after.
My asking price is less than what it should be and is non Negotiable.
The vehicle is priced to sell.
Standard models are fetching around 19000 and modified examples in good condition are 25000.
My price 19500 Strictly non negotiable.
Please contact me if you are serious and have the money to buy the vehicle.
0424 903 232
Rego: WTR025
VIN: RNN14-051300
KM: 155xxx
Previous ad: https://www.gtiroz.net/topic/15785-sold-sa-‘91-red-built-motor-15k/
Buy this car Kelvin!!
Edited by Give In
You gonna chuck in 7k? 🤣
Done, i'll get my people to talk to your people.
  • Haha 1
Price drop - $15.5k
Factory Sunroof central Locking and Geniune Factory Front Rear Strut braces as well as Sway Bars.
Factory electric Windows ABS and Expensive Race spec Green stuff Brake Pads on front
Red Stuff on back with reciepts
Mericulously maintained and with over $26,000 in reciepts
*Engine*
• Spool Rods
• Maintanace
* Suspension
Just over $5500 spent on Fully Adjustable coil overs Nolathane Bushes were needed plus other bits
*Tyres
Only just fitted a set of Brand New 2019 stamped Brand new tyres.
Grips and Handles like a Go Kart minus the sore back
*Transmission*
• Exhaust
*ECU / Tune
Custom Dyno Tuned at only 10 psi and made 217 All Wheel Kilowatts at a conservative Tune.
LATEST Nistune Version 3 with Tuning Harness and software included
Z32 Airflow Meter
This Turbo and cam set up has the potential for over 350 All wheel Killowatts if pushed to 27psi which the engine and turbo is capable off.
However for me 200 plus all wheel killowatts is all I wanted reliably.
I dont push the car hard , I just wanted it built to last.
Standard models are fetching around 19000 and modified examples in good condition are 25000 .
My price 15,500 Strictly non negotiable. As I have found a car I've been wanting for quite sometime now. If the car sells then the price will go up and I'll be happy to keep the car If I dont sell it.
May be interested in swaps for a clean Mitsubishi EVO 7 May even add cash on top for the right one if value is greater
Other cars considered Nissan R34 GTT , Subaru STI , Nissan Silvia S15
Swap Value is $25,000
WOW!  This is going up in price faster than the stock market and bitcoin is going down.
Repeat
  • Haha 1
