[QLD] ‘93 Black built motor $14.5k
Ad taken off fb.
1993 Nissan pulsar Gti-R with 74 000kms. I have owned the car for several since 2015. The car has only traveled 2000km since.
SPECS
SR20DET
Forged CP pistons 87mm
OEM Nissan con Rods
ACL conrod and main Race Bearings
ARP headstuds and com rod bolts
1.2mm Cometic Metal head gasket
Kelford 186a cams
Kelford adjustable cam gears
Jun Reinforced Springs
New belts.
New Oem Crank pulley
New Iridium gtir spark plugs
New alternator
Aluminium radiator with silicon hoses
Bc coilovers
GFB geforce 2 electronic boost controller tuned with 5 different boost settings
Npc heavy duty organic clutch
Garrett Gt2971r Turbo
Turbosmart blowoff valve
Pod Filter
Hdi Front Mount Intercooler setup
Walbro 255 fuel pump
850cc Bosch injectors
Adjustable Fuel Pressure Reg
Haltech e8
3" exhaust system
Leather seats
Seriously buyers only! No test drives without the cash, car is currently registered. More information and pictures available on request.
$14,500
Joshua https://www.facebook.com/joshua.wilson95
Rego: 930YSI
KM: 74xxx
VIN: RNN14-150634
