[QLD] ‘93 Black forged motor $13.5k
https://www.gumtree.com.au/s-ad/crestmead/cars-vans-utes/93-nissan-gtir-pulsar/1223614164?
1993 Nissan GTIR AWD(4WD) SR20DET
Cammed/Forged Motor
Original 236xxxkms on dash...
Engine built November 2018 at 234xxxkms (1800kms new motor)
Fresh 6 months rego
ENGINE
Forged SR20DET Motor built November (2018) By Sideways Motorsport..
Forged Ross Racing Pistons
New OEM Nissan Rods (Can handle 400hp)
Crank Balanced etc
ACL Race Bearings
ARP headstuds
1.2mm Cometic Metal head gasket
Camtech 270/270° 12.4mm lift cams
New Timing Chains/Guides etc
Genuine Nissan Waterpump
New Fanbelts..
Supertech valve springs
Precision shims/guides
1700km since motor built
DRIVELINE/SUSPENSION/TURBO
Cube Speed Short shifter
5 Speed manual
Likewise Shifter
Nismo gearboot cover
Gti-r coil cover
Brand New XYZ coilovers (have receipts)
XYZ Adjustable Camber tops
Rear 3.7 r180 LSD Diff
Brand new Oil catch can lines
GFB electronic boost controller
Saas Boost Gauge
Dragon Digital WaterTemp Gauge
Brass Button Cushion Clutch
Garrett Gtx2867r Turbo Rebuilt by Mr Turbo
Garrett Gt28 Actuater
Stainless Intake pipe
Aeroflow Pod Filter
NEW PARTS
(Brand new) NISMO 62° Highflow Thermostat (reciepts)
(Brand New) Sterling 50mm Dual Core Aluminum Radiator (receipts)
ECU/FUEL SYSTEM
Walbro 460 e85 fuel pump
1000cc e85 injectors
SARD Adjustable Fuel Pressure Reg
Link G4 plug-in Ecu (s15 repinned)
3" Stainless Dump/2.5" Catback exhuast and 200cell cat into a 5zigen muffler
Have receipts for work done at sideways motorsport, Keeley motorsport and diversion garage....
Freshly Tuned to 206kw(280hp) at all 4 wheels on United e85 fuel By Diversion Garage (17/4/19)
Power was limited by 2.5" exhaust and no adjustable cam gears..
CONS
- Has a small coolant leak from water line from turbo to block - needs brass washers replaced
- Paint job isn't perfect has some fade on roof... paints 7/10
- Cold Start on e85 is a bit rough. Fine when up to Operating temperature - needs colder spark plugs
$15k ono with 6 months rego
$14.5k without rego/rec
Negotiable on price. Cash talks
Dylan 0423314160
Rego: 788WHR
VIN: RNN14-150072
KM: 236xxx
Previous ad: https://www.gtiroz.net/topic/15797-sold-qld-‘93-black-13k/?
Price drop - $14.5k
Original 236xxxkms
Engine built 2018 at 234xxxkms (1800kms new motor)
Fresh 6 months rego
Asking $14,500 with Rwc/Rego
If you know these cars you would know what these are worth.
ENGINE
Crank Balanced etc
ACL Race Bearings
ARP headstuds
New Fanbelts..
1800km since motor built
5 Speed manual
Saas Boost Gauge
Aeroflow Pod Filter
NEW PARTS
New Sterling 50mm Dual Core Aluminum Radiator (receipts)
New Link Pins Superpro Swaybar bushes
New front Cv boots inner/outter
S14 Silvia tie rod ends
New NGK BKR8E -11 Gapped to 0.6mm
ECU/FUEL SYSTEM
Link Ethanol Content Senser
1000cc Bosch e85 injectors
Have receipts for work done at Sideways Motorsport, Keeley Motorsport and diversion garage....
Freshly Tuned to 206.3kw(280hp) at all 4 wheels on United e85 fuel By Diversion Garage (17/4/19)
Power was limited by 2.5" catback exhaust and no adjustable cam gears..
CONS
- Has a small coolant leak from water line from turbo to block - needs brass washers replaced ($10) fix - just haven't gotten around to it.
- Resprayed some 5 years ago not a great job but presents well.. has some fade on roof will come up good with a cut/polish...
$14.5k ono with 6 months rego
$14k without rego/rwc
Don't like the price keep scrolling.
Price drop - $13.5k
Original 236xxxkms
Engine built 2018 at 234xxxkms (1900kms new motor)
Fresh 6 months rego
Asking $13.5k
Negotiable on price without rego/rwc
If you know these cars you would know what these are worth. And are getting harder to find....
ENGINE
Crank Balanced etc
ACL Race Bearings
ARP headstuds
New Fanbelts..
1900km since motor built
5 Speed manual
Saas Boost Gauge
Aeroflow Pod Filter
NEW PARTS/REPLACED PARTS
New Protek JB4218 Clutch Slave Cylinder
ECU/FUEL SYSTEM
CONS
- Has a mild coolant leak (easy fix)
- Distributer o ring weaping (easy fix)
- Paints not the best 8/10
$13.5k ono with 6 months rego/rwc
$13k without rego/rwc
