[NSW] Black stock $24.5k
Ad taken from PGA FB.
HI ALL, up for sale is my restored oem gtir umbrella model. Whats been done are as follows listed:
(PRICE IS NEGOTIABLE UPON INSPECTION)
(After cash sale ladies and gents)
(WILL COME WITH BLUESLIP) AND (TRANSFER PAPERS to put INTO YOUR NAME)
EXTERIOR
- closed door respray
- machined wheels and painted
- new tyres
- drivers oem baily channel rubber
- legal window tinting all around
Cons - looking for new passenger side baily channel rubber (torn)
INTERIOR
- new dash
- bride interior (refer photos)
- genuine floor mats
- new oem gear knob
- steering wheel retrim (oem wheel)
- genuine emergency flare
CONS no cd player
ENGINE/ENGINE BAY
- engine bay respray
- 3 inch manderal bend exhauste system
- coolant hoses replaced
- new waterpump
- evans waterless coolant (synthetic)
- new radiator
- new vacume hoses
- engine oil seals replaced
- transfer case seals
- cv shaft seals
- shifter bushing and solid mounting
- engine mounts and solid stabaliser mount
- new steering rack and mounts
- all new oils
- new battery
- new alternator/power steering pump and oil
- ac system cold and all checked and replaced ac o-rings before ac regas
- new brake master cylinder oem & fluid flush
- clutch master cylinder and slave cylinder
- heavy duty custom made clutch
SUSPHENSION
- bc gold coilovers new
- new  front sway bar link pins and rubbers
- new control arms(anti lift kit fitted)
- front wheel bearings
- rear bash plate
-  rear whitline sway bar upgrade and links
$21,000
Contact Jamil -https://www.facebook.com/profile.php?id=100001701140523
Rego:
VIN:
KM: 187xxx
Your content will need to be approved by a moderator
You are commenting as a guest. If you have an account, please sign in.
