[NSW] ‘94 White $22k
Ad taken off gtiroz fb.
Hey peeps, thought I’d give you guys first dibs before I advertise publicly
1994 Nissan Pulsar Gtir located in Sydney NSW currently sitting on 14x xxx km
It is with a heavy heart that I am putting my toy up for sale - took me forever to find what I was after; a clean white series 2 example
Over the last few weeks, I’ve had the following things done:
- Full fluid flush and refresh using nulon oils (coolant, spark plugs, rear + front diffs, gbox / transfer case, fuel + oil filters etc)
- Full strip down / removal of pretty much everything as the car wasn’t running 110% perfect. Found missing + mix match bolts, missing + cracked lines + hoses, perished stuff .. lots of nasties lol
Everything has been rectified and everything has been replaced
Full leak down test and compression test performed - excellent
Car runs mint and as it should now, perfect with no issues
- I’m ocd and pedantic, so I even went the extra mile and ordered a brand new walbro 255 pump, oem fpr, oem thermostat, oem shift linkage seal and oem dust boots
Within the last few thousand kms, the following things were done:
- NGK Iridium spark plugs
- Champion spark leads
- Ryco Panel filter (in original air filter box)
- New power steering and alternator belts
- New radiator & hoses
- New water pump
- New Bosch 440cc green top injectors
- KYB New SR Special shocks on all four corners (including new strut boots and bump stops)
- DBA T2 Kangaroo Paw front rotors
- Project Mu B-Spec front brake pads
- Bendix rear brake pads
- New steering rack boots
- Hankook Optimo K415 195/60/r14 all round
- Whiteline lower inner front and inner rear front control arm bushings
- New oem sump
I have a folder of documentation / paperwork / receipts for pretty much everything done to the car
There’s a few very minor superficial blemishes / negatives which include:
- front lower right hand side lip of bumper bar is scratched / scuffed
- front windows have had the tints removed by a monkey (glue / residue remains)
- front driver side door card / trim could do with replacing (bubbled up)
- rear parcel shelf has seen better days
Besides the above, the car presents very well
Mechanically solid, structurally straight, no rust, clean interior (no cracked dash)
It’s the perfect base to enjoy as an original example or to build upon into something special, the choice is yours
Will let it go for 22k
Currently unregistered but can organise nsw rego at extra cost
Any questions, don’t hesitate to pm me
Contact Jase - https://www.facebook.com/profile.php?id=688220034
Rego: unregistered
VIN: RNN14-151593
KM: 14xxxx
Previous ad: https://www.gtiroz.net/topic/15738-sold-vic-94-white-stock-14k/
This is very clean and also great to see the prices of these cars going in the right direction..
  • Like 1
