[VIC] ‘90 Black $15k
https://www.carsales.com.au/cars/details/1990-Nissan-Pulsar-GTiR-RNN14-Manual-4WD/SSE-AD-5848978
Up for sale is my 1990 Nissan Pulsar GTIR, i first purchased this car back in early 2011 and after spending a tonne of money time and love on it, i unfortunately had to sell it less than a year later due to work commitments. I promised myself i would buy another one and i did! The same very car i owned had come up for sale a few years later and i purchased it back again in 2015 and i have had it since!
It is now sadly time to sell it as i have too many vehicles and need to free up some money to expand my business.
Due to running my own business 6-7 days a week I have only ever had time to drive the car maybe a dozen times in the last 4 years,it has just sat in the garage accumulating dust, so its time it goes to someone who appreciates this car for what it is!
Less than 15,000 of these cars were made and i would say there would be less than half left,these cars will only go up in value!!
I dont even know where to start with the amount of mechanical work this car has had!
The majority of the following has been replaced with new items:
-Kumho ecsta tyres with ROH 16" Wheels
-Tinted windows (octane color)
-HKS POD FILTER
-King springs in the front
-New Battery
-Injectors cleaned,flow tested and replaced all the 'o' rings
-Nolathane Suspension bushes throughout the whole car!
-Walbro fuel pump
-Cusco Strut bar
-Slotted brake rotors and pads all 4 corners -Wheel bearings
-Engine and Gearbox Mounts
-Ball Joints
-Tie Rod ends
-CV Shafts
-Shock absorbers
-3 inch catback exhaust with punched out cat
-JVC Headunit with JL Audio Speakers
ALSO HAS A DASH MATT,AUTOMETER BOOST GAUGE THAT READS IN PSI,APEXI RSM(REV SPEED METER) AND HKS TURBO TIMER ALSO HAVE THE RARE NISSAN ORIGINAL FLARE AND UMBRELLA(THESE ARE $2k ALONE.)
sooo much more to list the car really needs to be seen to be appreciated!
-Engine has had new front and rear main seals,oil pan gasket,timing chain tensioner,rocker cover gasket,new ignition coil and rotor arm,drive belts and water pump as well as being fully serviced with new ignition leads and filters and all the oils flushed and replaced including power steering and brake/clutch fluids.
I have had the motor out and put in a new exedy heavy duty clutch (next one up from factory so very easy to drive and can handle more power) as well as replaced the gearbox with a low km one from japan
The paint has seen better days especially the roof (common issue on these cars) but i have had the car 5 stage clay barred and detailed it come up pretty good for almost 30 year old paint (new owner may consider to respray the car it would then look a million dollars!)
These sr20 motors share the same name as the ever reliable motors in the earlier nissan line up such as the s13,s14 and s15 as well as the bluebirds but are actually quite different and are quite hard to get to them to run right with a heap of vac lines and old school electrics but this one has taken me hours and hours of research to finally get it to run as if it had come from the factory! Most other gtirs will have idle and boost issues, this is so smooth comes on boost easily and just pulls hard!
I am selling with rego which expires mid may and i can sell with a rwc also, if you dont want a rwc i will negotiate on price. I will include a few original spare parts also depending on sale price.
PLEASE NO LOW BALLERS AND TIME WASTERS OR 17 YEAR OLDS ON YOUR LEARNERS. I WORK 6-7 DAYS A WEEK SO DONT WASTE MY TIME IF I DONT ANSWER YOUR CALL SHOOT ME A TEXT MESSAGE AND I WILL GET BACK TO YOU.
Rego: 1DA4VT
VIN: RNN14-003988
KM: 170444
Your content will need to be approved by a moderator
You are commenting as a guest. If you have an account, please sign in.
