[SA] ‘93 Black needs work $9k
Ad taken off gtiroz Facebook page.
1993 GTiR - Black - 188,000 kms
Fair condition - mostly stock with lots of parts, restore, build or track as is, paint + some trim + some gaskets flip it for $$$, don't have the money to do it myself - need to put some money into my house - regretful sale.
Needs a re-paint, it has clear coat peal and fade.
Need some minor interior trim - dash is very cracked, rear 'door' cards damaged but fixable, cracked centre console surround, needs driver side window controls replaced - this maybe replaced before sale, Passenger side lock has the typical issue, see forum for fix.
Gearbox has bad 2nd and 3rd synco - so easing it 2nd and 3rd is mostly good but a tiny bit bad, has been like this since I bought it - just waiting for it to die to a full engine bay tare down, comes with 1 good spare box and another with 2nd and 3rd gears stripped.
Owned it for the last 7 years, with less then 20,000 kms in that time - had a daily I would use 70% of the time, driven to and from Adelaide (600 kms round trip once or twice a year)
2.75" exhaust system with dump and proper muffler - JASMA Approved, builds boost from 2,800~ rpm.
Cusco Front LSD
Heavy duty clutch - brass button IIRC
Fumoto(?) oil drain valve
GK slip in soild rear sub frame collars
Aftermarket Alloy Rad
Ancient 2001 xplode Sony CD player with after market speakers - should all be replaced, but they are stock size.
Wiring for AMP and sub in boot.
**Air-Con** delete
Factory size Pirelli p06 tires on stock wheels with lots of tread but need rotating - centre caps need paint.
Factory options:
Heated mirrors (drivers has been replaced during compliance)
Illuminated key ignition
Power windows, power locks.
Spares:
4 injectors
Injector refresh kit
2x AFMs
2x pod filters
2x set of spark plugs
2x o2 sensors
Original Radiator
Intake pipe - stock
Dual SBC Boost controller
Turbo Timer
Clutch slave cylinder
Clutch HEL braided line
1x gearbox in 'good condition' but never checked
1x gearbox with stripped 2nd and 3rd - with current gearbox should = another good box.
Walbro fuel pump 255L
Rear hatch - has rust but glass in good con.
Rear spoiler in dark blue - no screw caps tho
Window washer bottle
Fog lights - non nissan/nismo
Factory dump pipe and exhaust to cat
1x decat pipe from 2.75" system
1x guttered cat.
1x alternator
History;
warmed up and cooled down 95% of the time.
Dropped the fuel tank and replaced all the fuel lines, treated all the minor surface rust on sub frame etc.
Water pump and turbo replaced at some point before I got it - see GTiR oz thread.
Power steering leaks at full lock - unsure but suspect the wrong fluid was used so it will need to be replaced.
3 keys, 1 plain, 2 s15 style.
Atm this a of bit EOI and draft - will add more as I remember it, also have thread on GTiR OZ under 'ZiG' iirc - will travel to Adelaide for genuine buyer with proof of funds.
Will swap for daily/something of interest/van/ute/wagon with cash my way.  In no hurry to sell, and as prices just keep on rising the price is fair but I am negotiable - low ballers will be ignored and/or blocked (if you can get one cheaper/better then this then do it, don't bug me about it 🙂 )
Rego: S821AKC
VIN: RNN14-150096
KM: 188000km
Previous ad - same seller: https://www.gtiroz.net/topic/12442-sa-93-black-45k-with-lots-of-spares/?tab=comments#comment-243146
Contact: Sebastian https://www.facebook.com/profile.php?id=100000276315767
Now on gumtree
https://www.gumtree.com.au/s-ad/jamestown/cars-vans-utes/nissan-pulsar-gtir-jdm-tubro-awd-sr20det/1205352241
Fair condition - mostly stock with lots of parts, restore, build or track as is, paint some trim some gaskets flip it for $$$, don't have the money to do it myself - need to put some money into my house - regretful sale.
2.75" exhaust system with dump and proper muffler - JASMA Approved, builds boost from 2,200~ rpm, was from the MCN(MMC?) track car.
Cusco Front LSD
Fumoto) oil drain valve
GK Tech slip in solid rear sub frame collars
**Air-Con** delete
Laptop with EcuTalk consult cable, old pen touch laptop with folding screen.
Factory options:
Spares:
4 injectors
2x AFMs
2x pod filters
2x BOV's - ARC and
2x o2 sensors
Original Radiator - plastic drain plug has rounded head.
Intake pipe - stock
Blitz Dual SBC Boost controller (solenoid and wiring still in place)
Turbo Timer (wiring still in place)
Shifting bushes from Jesse in Canada
1x gearbox with 3rd main gear and 4th input gear stripped of all teeth main shaft rear bearing is stuffed - with current gearbox should = another good box.
1x guttered cat.
1x alternator
History - Imported in 2002.
Previously to me owning it;
sometime between 10/10 and 12/10
Air Con removed
new windscreen
new water pump
new thermostat
sometime between 05/08 and 03/09
Turbo replaced
Clutch master cylinder replaced
Power steering leaks at full lock - unsure but suspect the wrong fluid was used so it will need to be replaced/rebuilt.
Have add more as I remember it, still a few spares unlisted also have thread on GTiR OZ under 'ZiG'- will travel to Adelaide for genuine buyer with proof of funds.
Sebastian - 0422079877
*bump* this one is mine - been offer 6k a few times, also I have radiator diversion plate that was group buy on here awhile ago that will come with - the spare transfer has been sold too, so not included with sale.
