[SOLD] [NSW] '93 Candy Apple Red - $10k
https://www.gumtree.com.au/s-ad/st-helens-park/cars-vans-utes/nissan-gtir/1178475235
https://www.carsales.com.au/cars/details/Nissan-Pulsar-1993/SSE-AD-5283605/?ret=search-alert&utm_source=internal-carsales-notification-centre-search-alert&utm_medium=email
Previous ad: https://www.gtiroz.net/topic/13639-nsw-93-candy-red-85k
VIN: RNN14-102152
Rego: GTI69R
Quote
Nissan pulsar gtir - originally super white 531
Rego: Gti69r
180,000km
Head work:
Jun soild lift cams 264 10.8 lift
Jun spring kit to suit cams
Tomei rocker stoppers
Tomei cam gears
New rocker arms
Shimmed head to spec from jun
Head cleaned and tested by lovvell engineering
ARP2000 head bolts
Tomei Japan head gasket with 87mm bore
Blocked tested and cleaned and fit to factory spec
1000cc Bosch injectors
Bigger fuel rail made by jem cos you can’t buy one as they told me.
All new fuel lines from the tank to motor to run e85 fuel.
Hks 2871r turbo with external gate welded to stock manifold.
External gate tested and springs replace by jem
3inch exhaust from the turbo back custom made by jem as it was to close to the tail shaft
Z32 air flow meter
Hks pod filter
Return flow intercooler
Aem e85 fuel pump
Aem tru boost electric boost controller
Apexi power fc Ecu with hand controller
Alloy radiator with twin fan set up
Intake manifold welded and bov removed
Cusco oil catch can
Open to offers
Looking to swap for a 200sx nice gti open to other cars also
Have 8k in recent receipts for the car
$15,000
0452566268
Rego: GTI69R
