Welcome to [GTIROZ]
Welcome to the home of the GTI-R Owners Club Australia!
GTIROZ was established in the year 2000. We are a free-to-join non-profit car club based on a network of enthusiast owners of the JDM Nissan Pulsar GTI-R from around Australia.
We provide a searchable, organised archive of collective knowledge, and a place to share the enjoyment and frustrations of owning these rare and unique vehicles.
All Australian GTI-R owners are warmly invited to join, access our many years of historical data and share their ownership experience
Followers 0
scotties
[QLD] Black/White 1993 Gti-r $8,000
1 post in this topic
Year: 1993
Colour: Black / White
Reg & Expiry: 3 months
Kilometres: 149K
Price: $8,000
Contact: 0409 112 560
G'day guys,
Been sitting on this decision for about 6 months now and I have finally decided to see if I can find the car a new home. Since I have purchased her, we have only traveled about 5000kms in 3.5 years. Most of the time been sitting in the garage and slowly sourcing bits and pieces. I'm keen to see it go to someone who would like to put the finishing touches. It's reasonably stock apart from the gearbox which has only just been fully stripped and reconditioned with a 1-4 synchromesh PPG gear set. Chasing a box like that alone isn't cheap! The car has been dipped in a gloss white EBC coating and is black underneath. The bonnet and roof were fading most of the panels are fine otherwise. I have a 4 page list of parts bought/replaced/refurbished which I’ve listed below.
Following Parts 3000kms old or less carried out at JAZ performance Brendale.
Full strip, seals, bearings PPG 1-4 synchromesh gear set
High torque button clutch
Upgraded pressure plate
New 3inch stainless steel AM performance dump pipe exhaust front section.
Walbro 250lphr fuel pump
New front slotted rotors & ultimate brake pads
New vented rear rotors and brake pads
New harmonic balancer
New spark plugs iridium $
New water pump
Reconditioned clutched master cylinder
Reconditioned clutch slave cylinder
New manifold studs and manifold gasket
New turbo actuator and turbo gaskets
Lighten flywheel
New bushes & link pin bushes "d" rubbers front & rear sway bar
Rocker cover gasket spark plug tube seals
Cv rack boots
Speedy sleeve
Rear mail oil seal
Fully reconditioned rear brake calipers
Front crank balancer seal
New air-con & power steering belts
Full silicon heater hose kit
2 new gearbox & 1 engine mounts
New thermostat and housing
Full turbo silicon kit
Turbosmart fuel pressure gauge (in-line)
Autometer boost gauge phantom 2
Autometer wideband air fuel gauge
White face dial kit
Sparco black gear shift knob
Turbo XS boost controller
Coolant flush, upper cylinder head treatment, all diff oils flushed and replaced.
Brackets, hose clips, clamps, hoses, grommets, screws, nuts and bolts replaced where missing or required with new parts.
Parts included
Turbosmart v-port BOV
Apexi AFM adapter with apexi filter
Brand new door seals
Brand new rear windscreen seal
New took hook cover
Ziggen short stainless muffler
King springs super lows
18inch Saas wheels
Pioneer Bluetooth CD receiver
JVC 6 inch 3way speakers
Engine compression tested at 160-158psi across all 4 pots
Box of spare parts heat shields, arch trims, hoses etc
It's a strong base with plenty of potential!
I would like to keep her as they are slowly getting harder to come by, but I have one too many cars and it's just not getting driven enough.
Would be selling unregistered only due to 2 things  1.exhaust clearance is below 100mm 2.fuel neck leak at rear when more than ½ a tank full.
I'm asking $8000 pretty firm, genuine sale
Any questions please feel free to contact me on 0409112560
Cheers,
Scott
Edited by scotties
Share on other sites
Your content will need to be approved by a moderator
You are commenting as a guest. If you have an account, please sign in.
×   You have pasted content with formatting.   Remove formatting
  Only 75 emoticons maximum are allowed.
Followers 0
