nic009
[SOLD] [QLD] '93 Black GTiR $7k
SOLD! 😛
1993 model, front mount, 3" turbo back exhaust, Greddy E-Manage, 16" Advanti Rims and D2 Coilovers
Ex- Damon R - had below mods in Damon's ownership. Some were removed between the time he traded it in to when Nic purchased it.
Modifications:
• D2 Street Coilovers (7F – 5R) (Lowered F:335, R:325)
• Nismo Front Strut Brace
• Cusco Rear Strut Brace
• K&N Extreme Top Pod Filter
• 3" MS Exhaust, turbo back, twin muffler setup
• Split Dump Pipe
• Hi-flow Cat
• DBA Slotted Rotors Front and Rear
• Bendix Ultimate Pads
• Braided Brake Lines
• Nick’s Performance Clutches Full Face Organic Clutch
• Reinforced Clutch Fork
• Plazmaman Front Mount Intercooler Kit
• 16" Volk Racing TE37s with 205/45 Yokohama S-Drive rubber
• Rays Engineering Lock Nuts
• Autometer Boost Gauge
• Apexi Power FC
• Greddy Profec e-01 Electronic Boost Controller
• Garret GT2871R Turbo (52 trim / 0.86 Exhaust Housing)
• Braided Turbo Oil Feed Line
• Nismo 555cc Injectors
• Z32 Air Flow Meter
• Splitfire 8.8mm Ignition Leads
• Odyssey Battery
• Walbro 500HP Fuel Pump
• Top mounted Mocal oil cooler w/ braided lines and Sandwich plate w/thermostat
• Custom Air Box
• Custom Air Intake Pipe (Pre-Turbo)
• Cold Air Induction with Bell mouth entry
• Custom Spark Plug Cover Plate
• Sard Fuel Pressure Regulator with Setting Gauge
• Whiteline Rear Adjustable Blade Sway Bar
• Oil Catch Can
• Brake Cylinder Stopper
• Clutch Pedal Support Bracket
• Tinted Windows (Darkest Legal Tint)
• Immobiliser
• Aftermarket Remote Keyless Entry
• Isotta Aluminium Racing Pedals
• Tow Hook Cover
• Clear Side Indicators
• Nismo Original GTiR Gear Knob
• Relocated Washer Bottle Setup to Boot (well, I helped Ash and supplied the Jim Beam)
• Removed roof lining and re-attached cross members to stop roof rattle
Audio:
• Alpine D-105E Head Unit
• Alpine Integrated Bluetooth
• Focal 6" Splits - Front
• Focal 6” Rears – Rear
• Fusion Powerplant 1404 Amplifier
• Fusion Powerplant 12" Subwoofer
• Custom Sub Box to go around rear strut brace
• Dynamat sound deadening for roof
Replaced/Reconditioned:
• Replaced Water Pump
• Reconditioned Clutch Mater Cylinder
• Replaced Slave Fluid Line
• Replaced Fuel Filler Neck (No More Leaks)
• New GTiR Aerial
Rego: NIC009
VIN: RNN14-102101
KM:
Previous ad: https://www.gtiroz.net/topic/624-sold-black-94-gti-r/
