Followers 0
IsaGTiR
[QLD] 1993 White GTiR $5.5k (Townsville)
34 posts in this topic
Have found another GTiR through Facebook for sale. Told the guy I'd advertise it For Sale on here. I will have pictures of it tomorrow, but for now a list of mods thanks to copy and paste..
93 Nissan Pulsar GTi-R 105,XXX Klms. $5500 White in colour, 204kw at the wheels on 17 PSI, has an E-boost one setting at 8 PSI the other at 17PSI .. was rebuilt at 80,000Klms by the previous owner.. new battery went into it couple of weeks ago.. its running now however leaks a oil once started.. Mechanics to look at it and got told it would need about $3,000 to get it going like it use to..
* Niztune ecu
* Z32 afm
* CES HPC coated Dump Pipe
* Custom Exhaust Specialist (CES) stainless 3 inch exaust from the dump pipe back. (This alone was $2500)
* Cusco Oil Air separator
* Stainless steel 3 inch metal cat high flowed by CES
* Custom Carbon Fibre Airbox which completely encloses UniFilter Pod
* Port matched the throttles
* Street Force Cylinder Head (Ported Head to his specifications see website)
* Reshimmed head solid valve train
* Jim Berry Race Clutch 4 puck, solid centre button clutch with Carbonetic friction plates. 28000lbs of clamping pressure!
* Gearbox was completely refurbished with new bearings(NTI) and seals during the engine build.
* Pivot and selector fork replaced
* turbo timer (Hidden)
* Stock turbo, with braided oil and water hoses
* HKS SSQV (Blowoff Valve)
* ALC Metal Gasket (From tweakit.net)
* Turbo and Manifold Gaskets all replaced
* Walbro 255L/hr fuel pump
* SX Billet Aeromotive Fuel regulator
* TurboSmart E-Boost 2 boost controller
* Clutch slave/master was replaced all boots replaced
* Slotted DBA Gold Rotors
* 4 x Goodridge Braided brake lines
* GMax 17x7 rims
* Factory front strut brace
* Whiteline rear strut brace
* Whiteline 4 point under body brace
* Entire catalogue of Whiteline bushes
* Tein Super Street coilover suspension (Aus Spec) with front Camber top plates
* Tein in car EDFC module
* 2 x Sparco Torino Race Seats RRP on these are 1200 each!
* Nakamichi Head Unit with remote
* Nakamichi Sub and Amp (Custom install in the boot with a false floor very nice and neat)
* Focal Audio Utopia Series Splits in the front RRP on these are $1500!!
* 2 x 6x9 Kenwood Splits speakers on the rear parcel
As stated, will have pics tomorrow.
Why is it leaking oil and where from?
He really won't have any chance of selling it if he does not give up some more details.
Copy and pasted
"Ill have pics up tomorrow man... I wouldnt be able to tell you whats wrong with it as im not as mechanically minded as i would of liked... Ill get it looked at sometime this week to find out whats wrong with it"
And then " yea doesnt sound healthy splatters alot.. leaking heaps of oil and was blowing alot of smoke last time i started it"
here' you chance to get your shell. buy it and strip it. you'd make money back easy
kelvin
Are you going to look at it Kyle? Sounds like it's got all the good shit on it already. As Kelvin said, you are looking for a shell anyway.
Although rebuilt 25k ago and it's leaking oil and running like ass already? perhaps it's had a hard time of it. Pics will be interesting.
Im thinking about doing a trip down to Townsville to suss it out.. Just gotta find the time to get down there..
25k and leaking oil tells me it's been neglected or not done right.
Its probably something as simple needing a new gasket, a mechanic probably quoted 3k cos he thinks its a harder job than it probably is
Yeah, pretty much, but if it's blown a gasket in 25k................. depends on which one.... but could be a grenade.
my rocker cover gasket leaks a little, for 5.5k, you'd strip the motor down and check everything anyway
Two things one it will be shame you would even strip that. Second must be major stuffed for that price in such good nick.
Exactly, I have an account but I am not on there, never use it unless to look at things like you posted, that don't work.
This is the message I get
"This content is currently unavailable
The page you requested cannot be displayed at the moment. It may be temporarily unavailable, the link you clicked on may have expired."
so go figure!
so go figure!
1+
Followers 0
