Followers 0
arkade
[WA] 1994 Black GTiR Unfinished Project
19 posts in this topic
Edit: I had wanted to sell this in one go because I was under the assumption I would be able to sell certain parts easily but would be left with the chassis. I was made, and accepted, an offer on the chassis and will now sell the remaining parts separately.
Year: 1994
Colour: Black
Reg & Expiry: Registered until December (I've kept it registered this whole time)
Kilometres: 14x,000
Contact: arkade@gmail.com
Details:
I imported my Black 94 RA GTiR in 2005 and loved it. Did a few bits and pieces on it like installing a FMIC, relocating the battery to the boot and giving it an Apexi intake. Lost my licence and decided I would do some more serious things to the car while I was suspended.
I bought a built engine and some other parts off another forum member and went to work. The gearbox is on the engine and the engine is in the car. And that's where it ended.
Long story short, I don't have the skills, patience or tools to do what was required and the car has been sitting in my garage for a couple of years without me touching it. It depresses me every time I see it and I'm ashamed it's come to this but I'm now looking to find it a more deserving home.
At this stage I want to get rid of it all in one go so am after EOI's for someone to arrange to pick it up on a flatbed with all the parts and drive it away into the sunset.
Engine
Garrett 2871 52 trim .86 A/R
PowerFC with hand controller
Sard 700cc injectors
ACL race series 87mm pistons and rings
ACL race series bearings
Camtech 270 cams
All new seals
Tomei valve springs
Tomei retainers
Tomei cam gears
Trust rocker arm stoppers
New lifters + shims
New valve guides
Eagle h-beam rods
Prepped Crank
Fully balanced bottom end
New water pump
New oil pump
New hose kit
ARP head stud kit
Cometic headgasket
Head build by Wilkins Performance
Sard fuel pressure regulator
Braided turbo oil and water lines
Odyssey battery in boot
Q45 air flow meter
Apexi power intake
Bosch 984 fuel pump
Hyrbid front mount intercooler
Custom solid engine mounts
New knock sensor
Drivetrain
JUN Lightened flywheel
Custom clutch friction plate and cover
Brake master stopper
Braided clutch line
Clutch pedal reinforcement bracket
Reinforced clutch fork
New NTN release bearing
Whiteline front strut brace
Handling
OZ racing 15" rims (shagged)
Extended tie rod ends (existing ones busted)
Lowered King springs
Exterior
Clear side repeaters
Average paint
Things to note
Engine has not run since I bought it
Stock exhaust is completely buggered, new one will be required
Stripped thread on exhaust housing of turbo
Exhaust manifold, turbo and lines, FMIC, various vacuum lines and electrics remain unattached
Pics
Ahhh dude. And to think last time I talked to you (couple of months ago) you were so keen on finishing it!
Dont want to make a "lowballer" offer.. Can anyone help on how much all of this would be worth?? IF I buy, I'd sell most parts..
I would expect you would be looking as a bottom end figure of at least $8000 considering the work done already, which I don't expect the seller would be looking for less, maybe some more.
Plus you would have to wear the cost to ship it from Perth to Cairns, so all up for you I would expect no change from $9000, as a rough ball park guesstimate.
But I could be wrong, so why don't you contact the seller and have a chat instead of getting us to do your homework for you.
As you have stated you are heading overseas, I don't believe there is a quick buck in this if that is what your looking for.
Remember, you are looking for a shell so you can build two R's, a quickie and a couch potato for your dad :roll:
I'll get some pics ASAP but for now try to imagine a black GTiR missing a bonnet, radiator etc and covered in dust.
Kyle: Around what Gary said but I acknowledge what work still remains to be done and have seen a fair few nice complete cars going for low prices so am flexible in that regard.
hey how much u want for ur car
Basicly that means make an offer on what you think its worth and go from there
FYI, rolling shell is gone. just running gear and parts left now
kelvin
Can u private mail me ur number so I can call u about it thank u
I will update this thread and create a new one for the remaining parts ASAP
Followers 0
