[QLD] 1993 White GTiR $5.5k (Townsville)
#1
Posted 19 September 2011 - 07:30 PM
93 Nissan Pulsar GTi-R 105,XXX Klms. $5500 White in colour, 204kw at the wheels on 17 PSI, has an E-boost one setting at 8 PSI the other at 17PSI .. was rebuilt at 80,000Klms by the previous owner.. new battery went into it couple of weeks ago.. its running now however leaks a oil once started.. Mechanics to look at it and got told it would need about $3,000 to get it going like it use to..
* Niztune ecu
* Z32 afm
* CES HPC coated Dump Pipe
* Custom Exhaust Specialist (CES) stainless 3 inch exaust from the dump pipe back. (This alone was $2500)
* Cusco Oil Air separator
* Stainless steel 3 inch metal cat high flowed by CES
* Custom Carbon Fibre Airbox which completely encloses UniFilter Pod
* Port matched the throttles
* Street Force Cylinder Head (Ported Head to his specifications see website)
* Reshimmed head solid valve train
* Jim Berry Race Clutch 4 puck, solid centre button clutch with Carbonetic friction plates. 28000lbs of clamping pressure!
* Gearbox was completely refurbished with new bearings(NTI) and seals during the engine build.
* Pivot and selector fork replaced
* turbo timer (Hidden)
* Stock turbo, with braided oil and water hoses
* HKS SSQV (Blowoff Valve)
* ALC Metal Gasket (From tweakit.net)
* Turbo and Manifold Gaskets all replaced
* Walbro 255L/hr fuel pump
* SX Billet Aeromotive Fuel regulator
* TurboSmart E-Boost 2 boost controller
* Clutch slave/master was replaced all boots replaced
* Slotted DBA Gold Rotors
* 4 x Goodridge Braided brake lines
* GMax 17x7 rims
* Factory front strut brace
* Whiteline rear strut brace
* Whiteline 4 point under body brace
* Entire catalogue of Whiteline bushes
* Tein Super Street coilover suspension (Aus Spec) with front Camber top plates
* Tein in car EDFC module
* 2 x Sparco Torino Race Seats RRP on these are 1200 each!
* Nakamichi Head Unit with remote
* Nakamichi Sub and Amp (Custom install in the boot with a false floor very nice and neat)
* Focal Audio Utopia Series Splits in the front RRP on these are $1500!!
* 2 x 6x9 Kenwood Splits speakers on the rear parcel
As stated, will have pics tomorrow.
#2
Posted 19 September 2011 - 07:55 PM
#3
Posted 19 September 2011 - 08:03 PM
Is this Anthony's?
Nope. His name is Jared Peever
#4
Posted 19 September 2011 - 08:07 PM
He really won't have any chance of selling it if he does not give up some more details.
#5
Posted 19 September 2011 - 08:18 PM
"Ill have pics up tomorrow man... I wouldnt be able to tell you whats wrong with it as im not as mechanically minded as i would of liked... Ill get it looked at sometime this week to find out whats wrong with it"
And then " yea doesnt sound healthy splatters alot.. leaking heaps of oil and was blowing alot of smoke last time i started it"
#6
Posted 19 September 2011 - 08:27 PM
#7
kelvin
#8
Posted 19 September 2011 - 08:58 PM
#9
Posted 19 September 2011 - 11:09 PM
Troy. I can look at it for you.
Want contact details?
#10
Posted 19 September 2011 - 11:27 PM
#11
Posted 20 September 2011 - 01:17 AM
Although rebuilt 25k ago and it's leaking oil and running like ass already? perhaps it's had a hard time of it. Pics will be interesting.
#12
Posted 20 September 2011 - 06:56 AM
#13
Posted 20 September 2011 - 10:04 AM
#14
Posted 20 September 2011 - 10:43 AM
Its probably something as simple needing a new gasket, a mechanic probably quoted 3k cos he thinks its a harder job than it probably is25k and leaking oil tells me it's been neglected or not done right.
#15
Posted 20 September 2011 - 10:44 AM
#16
Posted 20 September 2011 - 12:21 PM
#17
Posted 20 September 2011 - 06:39 PM
#18
Posted 20 September 2011 - 06:41 PM
#19
Posted 20 September 2011 - 06:43 PM
#20
Posted 20 September 2011 - 06:44 PM
This topic is locked
View Garage
